Create Path Intent for Future Path Diagnose
You can define a Path Intent to document the baseline behavior and diagnosis logic for a specific network path. This helps you automate troubleshooting and quickly identify issues when they occur.
Each path can have one or more associated intents. Once defined, a Path Intent can be:
Triggered automatically by the Trigger Automation Framework (TAF) or Auto Intent
Executed manually when needed
The built-in Path Intent is stored directly in the path object and used as a reference for automated diagnosis.
The system provides several methods to create a Path Intent.
