Define Variable
Variables in NI can be categorized in the following ways:
Categorized by Variable Classification
| Variable Classification | Description | Sample |
| Parser Variable | Parser Variable refers to the variable extracted from CLI commands under the Define Variable tab in NI. | ![]() |
| Compound Variable | Compound variable can convert the single variable into different formats or calculates new variables using two or more existing single variables. | ![]() |
| Compound Table | Compound table can merge two table variables in the same NI into one table variable, including merged table, sub table, and appended table. | ![]() |
| Macro Variable | Macro variables are variables with a pre-defined default value. | ![]() |
| Task Variable | Task variable can be read and written across home intent and follow-up intents to pass information from home intent to any follow-up intents. It can be used in the Triggered Automation Framework (TAF), auto intent, and bot. | ![]() |
| Critical Variable | Critical variables are used to qualify devices for the intent template when it is replicated to related devices. All variables used in diagnosis and CLI commands can be set as Critical Variables. | ![]() |
| Signature Variable | The signature variable is a specific type of variable, and it is aimed to expose the main variable values used in the parser when NI is used for NIT replication. It can also be used in ADT for outputting values. | ![]() |
| Built-in Table | The device built-in data are supported in intent, such as Route Table, Topology Table, and NCT. | ![]() |
| ADT | ADT is an extended global data table for managing the critical network assets and network intents associated with those network assets. | ![]() |
| Built-in Variable | such as $this_device, $device_name. | ![]() |
Categorized by Variable Type
| Variable Type | Description | Sample | ||
| String | Match any single word. | Device hostname can be parsed by parser with string variable, such as hostname CA-TOR-SW1 --> Hostname $hostname (string).![]() | ||
| Mstring | Match one or multiple words.
| device neighbor can be parsed by parser with mstring variable.![]() | ||
| Int | Match any whole number. | ![]() | ||
| Float | Match any double-precision IEEE 64-bit (8-byte) floating-point number. | Device version can be parsed by parser with string variable, such as Version 15.4 --> Version $version (float).![]() | ||
| Object | See Support Native Objects for more information. | | ||
| Bool | See Support Variables of List Type and Bool Type for more information. | |||
| List | ||||
| Table | Match any information that can be converted into a table. | Device ip route can be parsed by parser with table variable.![]() |
