Logo
Compound Table in Network Intent
Compound Table includes Merged Table, Sub Table, and Appended Table, allowing you to preprocess data for easy use in diagnosis. You can perform more types of DB-style merging on table data.
You can also define the compound table from the following entrance.
  • Merged Table
  • Sub Table
  • Appended Table
Compound Variable in Network Intent Define Merged Table
