Data Retrieval Result
When you execute CLI commands or retrieve live data through a runbook, read the following reference to interpret the data retrieval status.
Retrieval Result for Individual Command or Data Type
The following table describes the status of retrieval results for individual commands or data types:
IconExplanation
Command or data type has been successfully retrieved from the selected device.
Command or data type cannot be retrieved from the selected device.
Command or data type is not applicable to the selected device.
Information Note: This result is only available in Retrieve Live Data.
Retrieval Result for Device
The overall data retrieval status for a device is determined by the combined results of its associated CLI commands and selected data types. The following table describes the status of retrieval results for devices and related combinations:
IconExplanationCombinations for Individual Results
No failure records of data retrieval on this device.
No success records of data retrieval on this device.
The selected device has both success and failure records.
All commands or data types are not applicable to this device.
