R12.1 Project-2025Sep08
Live Device Data
The following types of live device data can be retrieved for task execution in a domain:
Note: The available data types may differ depending on the analysis task types and device types. |
- Configuration File
- General Data Tables, including: Route/ARP/MAC/NDP/STP.
- NCT Table, including:
- Azure Neighbor Relationship Table,
- IPsec VPN table,
- BGP All VPNv4 Advertised Route Table,
- Cisco Coverage Summary,
- GRE Tunnels,
- NAT Table,
- IPv6 Route Table,
- BGP advertised-route table, and so on.
- CLI Command Outputs: The outputs of the executed CLI commands.
For example, the CLI outputs of the show ip bgp summary command or the show ip eigrp neighbors command.
