Runbook Document
NetworkBrain provides valuable data for network engineers, including automation results, troubleshooting guidance, network change records, and device inventory. You often need to present this information in clear, well-formatted documents. The improved 'Export to Word' feature, along with the new Content Template Manager, empowers users to create and customize multiple report templates, while AI tools transform report generation into a fast, one-click process.
How It Works
Follow this simple workflow:
  1. Add a document node to your runbook.
  2. Select a content template that suits your audience or goal.
  3. Choose the data you want to export, like runbook steps or results. Then, refine the Word report with the AI Document feature by giving natural language instructions—such as “Add an executive summary before Section I”—to quickly tailor it to your needs.
See the following topics:
