Setup Triggered Automation
Follow the steps to configure TAF to trigger diagnosis from the IT system:
  1. Define Integrated IT System
  2. Define Incident Type to Classify Different Tickets
  3. Define Triggered Diagnosis
    Information Note: The execution logs can be viewed iView Triggered Diagnosis Log.
NetworkBrain supports triggered diagnosis from external IT systems integrated with NetworkBrain, such as ServiceNow, Splunk, BMC Remedy. NetworkBrain also supports diagnosis triggered by Email.
