Work on Device Data
The Device Details Pane provides an overall view of each device by presenting various types of network data. In the Device Details Pane, you can:
- View and modify device/interface/module properties
- View and compare configuration file
- View and map topology
- View and compare pre-built data tables (neighbor table, route table, etc.)
- View and compare CLI command outputs retrieved in the benchmark tasks.
- Add notes to the device
- Customize physical images for the device
