Data Tables
In the Device Details pane, you can perform the following actions:
Data Table Supportability
Data Table
IPv4 Supportability
IPv6 Supportability
1
Route Table
Yes
Only support data retrieval via CLI
2
ARP Table
Yes No
3
MAC Table
Yes
No
4
NDP Table
Yes
5
NCT Table
Yes
Browsing Data Tables in Device Details Pane
  1. In the Device Details pane, select the Data Tables tab. Only the available data tables for the target device are listed.
  2. Click your interested table type to browse data in detail.
Retrieving Data Tables from the Live Network
  1. In the Device Detail pane, click to open the pop-up window.
  2. Click to retrieve live configuration.
  3. You could save the newly retrieved data table to the current baseline by clicking the icon.
  4. To review the original text data rather than in the table view, click the icon .
  5. Graphical user interface, tableDescription automatically generated
    Information Tip: To save the data table to the current baseline, close the window and open it again to enable the icon .
Comparing Historical Data Tables
  1. Click in the Device Details pane to open the Compare window for Data Table.
  1. You can select data tables from different times to compare. Exporting the comparison result is also available.
