Site is a geographical grouping of network devices, which can be used as device scopes, asset filters, and map/topology views. For example, you can divide your network into a hierarchy of sites based on country, state, city, region, and office location.
There are two types of sites in the system:
▪Container Site (
) — a parent site that contains leaf sites and other container sites. No devices are directly nested under a container site.
▪Leaf Site (
) — a child site that contains devices. The devices can be added manually or searched dynamically.
1.Click Site on the taskbar.
2.In the Site pane, right-click the target site and then select View Detail from the drop-down menu.
The detailed information is displayed, such as device count, and site map preview.
Site Manager is used to manage and maintain the sites in your domain. You can use either of the following ways to create or maintain a site hierarchy:
▪Create a Site Hierarchy by Importing a Spreadsheet
▪Manually create sites:
Note: By default, only domain admin, power users, or users with the Site Management privilege have access to the Site Manager. In a domain, only one user can open the Site Manager at one time.
