The fundamental element of a Qapp is called a node. Each node contains specific attributes and connects logically.
Example: Nodes in a Qapp Editor
The Qapp Editor has two types of tabs:
▪Execution Flow tab — define the execution sequence of the nodes within a Qapp, as well as the relations or conditions among the nodes.
oStart — the starting point of a Qapp. You can define the way of the Qapp to obtain devices at runtime within this node.
oStop — the endpoint to terminate a Qapp. You can define a message and the message will prompt when the Qapp executes this node.
▪Canvas tab — contain an internal workflow composed of multiple subnodes as follows.
The context menu in the Qapp Editor is as follows:
Icon |
Save the Qapp. |
Save as another Qapp. |
Run the Qapp. |
More operations, such as customizing functions and locking the Qapp. |
The following table introduces the system built-in variables in a Qapp.
Variable Name |
$_device |
A global PyDevice object representing the device on which the Qapp is running. It is a simple PyDevice object and not an array of PyDevice objects. The Qapp automatically loops through each of the selected devices. |
$_device_queue |
A variable representing the device queue table that the Qapp loops through. |
$_command |
The command on which the output is based. |
For more built-in variables, refer to the Global Data Repository (GDR).
