R12.1-2025Jul03
Browse Network Objects and Context Map
The system can support various types of networks and provides built-in views for them. The Network pane is used to manage, organize and provide various views for network resources discovered from traditional networks and SDNs.
Example: To view the context maps of a firewall in a traditional network:
  1. In the NetBrain desktop sidebar, open Network.
  2. In the Network pane, select Physical Network from the drop-down list and then select Device Type.
  3. Expand the Firewall folder and select a specific firewall.
  4. On the Context Maps tab, click Open Map to display the topology on a map.
  5. Click the Device Details tab to view its property and interface details of the firewall.
