Visualize GCP Network
Prerequisites
Discover your GCP network in NetBrain. For more details, refer to NetBrain Quick Setup Guide GCP.
User Flow
The general user flow of visualizing a GCP network in NetBrain is as follows:
- Understand GCP Network Tree
- Calculate Path Across GCP Network
- Build Data View Template to View More GCP Data
- Use Runbook Automation for GCP Network
- Integrate with Third-party Tools for SPOG
For more details about GCP network objects that can be visualized, refer to Supported GCP Network Objects.
For more details about supported GCP public services, refer to Supported GCP PaaS.
