Supported GCP Network Objects
The following table outlines all supported GCP networking objects:
| # | Icon | Object Name | Supported Features Details | Map | Topology | Path |
| 1 | ![]() | Google Organization |
| Yes | Yes | N/A |
| 2 | ![]() | Google Folder |
| Yes | Yes | N/A |
| 3 | ![]() | Google Project |
| Yes | Yes | N/A |
| 4 | ![]() | Google Region |
| Yes | N/A | N/A |
| 5 | ![]() | Google Zone |
| Yes | N/A | N/A |
| 6 | ![]() | Google VPC Network |
| Yes | Yes | Yes |
| 7 | ![]() | Google VPC Router* |
| Yes | Yes | Yes |
| 8 | ![]() | Google Subnet |
| Yes | Yes | N/A |
| 9 | ![]() | Google Virtual Machine |
| Yes | Yes | Yes |
| 10 |
| Network Virtual Appliances (FortiGate Firewall, Cisco CSR1000v, ASAv, Viptela, etc.) |
| Yes | Yes | Yes |
| 11 | ![]() | Google VPN Gateway |
| Yes | Yes | Yes |
| 12 | ![]() | Google Cloud Router |
| Yes | Yes | Yes |
| 13 | ![]() | Google Cloud NAT |
| Yes | Yes | Yes |
| 14 | ![]() | Google Load Balancer |
| Yes | Yes | Yes(Layer 3) |
| 15 | ![]() | Firewall |
| Yes | Yes | Yes |
| 16 | ![]() | Partner Interconnect |
| Yes | Yes | Yes |
| 17 | ![]() | Dedicated Interconnect |
| Yes | Yes | Yes |
| 18 | ![]() | Google Private Service Connect Endpoint |
| Yes | Yes | No |
| 19 | ![]() | Google Cloud Internet Gateway*** |
| Yes | Yes | No |
Notes: * Google VPC Router: Google VPC Router is not an actual object of Google Cloud. NetBrain creates the Google VPC router for each VPC Network as an interconnect/functional object to simulate the routing/security check function and store the VPC Network data like VPC Peering and VPC Subnet.
