Visualize AWS Network
Prerequisites
Discover your AWS network in NetBrain. For more details, refer to NetBrain Quick Setup Guide_AWS.
User Flow
The general user flow of visualizing an AWS network in NetBrain is as follows:
- Understand AWS Network Tree
- Calculate Path Across AWS Network
- Build Data View Template for AWS Network
- Use Runbook Automation for AWS Network
- Integrate with Third-party Tools for SPOG
For more details about AWS network objects that can be visualized, refer to Supported AWS Network Objects.
