R12.1 Project-2025Sep08
Visualize Cisco ACI Networks
With NetBrain, you can quickly visualize and understand a Cisco ACI fabric from the following aspects:
  • The objects in your Cisco ACI Fabric, such as ACI PODs, IPN, ISN, and their topology.
  • The detailed information about a node, such as properties, chassis, interfaces, and fabric extenders.
  • The overlay design over a Cisco ACI Fabric, such as logical layer dependency and connectivity inside or outside an application.
  • More data information by applying data views.
User Flow
Information Prerequisites: Make sure the discovery and benchmark of your ACI network have been completed.
The general flow of visualizing an ACI network in the NetBrain system is as follows:
  1. View your ACI network tree.
    NetBrain provides three views to help you better understand your ACI network:
  1. Calculate Path Across ACI Fabric.
  2. Apply Data View Template to Visualize More Data.
For more information about context maps, refer to Supported Context Maps of ACI Nodes.
