Map FAQ
  1. Question: Will a personal copy be refreshed automatically if I open the personal copy owned by others in the View-Only mode?
    Answer: To automatically refresh a personal copy, you can open the view-only personal copy and enable Auto Refresh. For more information, see Auto-Refresh a Map.
  1. Question: Is it possible to add an L2 neighbor device to an L3 map page (and vice versa)? What happens if I add particular L3/L2 connected devices to a map page?
Answer: You can add different types of topology links and neighbor devices on the current map page by extending neighbors or auto-link. For example, if you have selected L2 typology as the default auto-link type, the added L2 connected device will be linked automatically. For more information, see Extend Neighbors on the Map, Extend Layer 2 Topology, and Auto Link.
  1. Question: If I set auto link settings as defaults, will these default settings apply to all types of maps?
Answer: No, the default auto link setting will not apply to site maps and link group maps.
