Extend Layer 2 Topology
You can add the Layer 2 (L2) topology links on the same map page as the layer 3 (L3) topology links using the add neighbors or Auto Link feature.
Note: Before mapping layer 2 topology, make sure you have scheduled the Basic System Benchmark task to build the Layer 2 topology. For more information, see Schedule Basic System Benchmark Task. |
- Enter an IP address or parts of an IP address in the search bar to refine or locate interfaces. For more information, see Search for Devices.
- Drag the device icon from the search result to the current map page. The device will be added to a map.
- Click the
icon attached to the target device on your map to add the layer 2 neighbors.
Tip: The bus icon
is a medium used to simulate a layer 2 port on a map when the port is connected with more than 2 ports or devices.
- To view the port-to-port connectivity among the devices, right-click any blank area on the Map and then select Change Device Style > Expanded Style.
Tip: Scroll the mouse wheel forward to zoom in on the map and view more detailed information.
Further operations:
- To switch between logical ports and physical ports in port channels, right-click the blank area and then select Port Channel > Show All logic Ports/Show All Physical Ports. To switch to a specific link, right-click the link.
- To view the summary information about a port, point to the target port. To create a note for the port information, click the
icon. - To view the detailed interface information about a device, right-click the device and then select View Device Details. Click Interface under the Property tab.
