Auto Layout
The Auto Layout feature automatically arranges map objects based on the selected layout style. This helps you avoid manual adjustments and makes it easier to locate and manage devices on the map.
Layout Types
The system offers the following types of map layouts. See Layout Types for more details.
Apply Layout to Multiple Maps
You can also apply layouts to site or device group maps:
  1. Create a layout style for your map
  2. Apply it to the site map
  3. Save it as a sample
  4. Associate a layout to your Sites or Device Groups
