Request Editing Rights
If you want to edit a view-only map or network dashboard, you can send the editing rights request to its editor. You will get the editing rights after the editor's approval.
Request Editing Rights for a Map
Information Note: If you want to request the editing rights of a site map, you need to have the Site Management privilege first.
Information Note: Domain administrators and users who have the domain Management privilege can forcibly get the editing rights without any approval required.
  1. On the view-only map, select the View Only label next to the map name.
Information Tip: You can also click Map > Editing Rights on the map toolbar.
  1. Click Request Editing Rights on the prompted tip box.
  2. Click Request.
    The map editor will receive a system notification and an email (if your email server is configured).
Request Editing Rights for the Network dashboard
  1. On the view-only network dashboard, click the View Only tag next to the network dashboard name.
Information Tip: You can also click the  icon from the network dashboard toolbar and select Editing Rights from the drop-down menu.
  1. Click Request.
    The network dashboard editor will receive a system notification and an email (if your email server is configured).
