Dynamic Map and Visibility
Explore the following capabilities within Dynamic Map and Visibility:
- Dynamic Map Overview: Learn how the system visualizes your network in real time and integrates various data sources to give you a single pane of glass view.
- Search: Use the powerful search functionality to quickly locate devices, links, or network components. Filter and navigate large-scale environments with ease.
- Manage and Operate Maps: Interact directly with the map to explore device relationships, investigate anomalies, and drill down into specific elements. Pan, zoom, and select with intuitive controls.
- Create and Map Device Group: Organize your devices into logical groups for easier management and targeted analysis. Learn how to create custom groups and map them for quicker visualization and control.
- Visualize Network Topology: View your infrastructure in a hierarchical tree structure. Understand relationships and dependencies at a glance while navigating through layers of your network.
- Work on Device Data: Dive into individual device data, such as device properties, Interface properties, configuration, topology, CLI commands, and Physical images logs, and alerts.
- One-IP Table: The One-IP table records all IP addresses in the current domain discovered by the system and their properties, including LAN segment, MAC address, vendor, connected switch port, VLAN ID, DNS name, description, and VLAN group.
About an Inventory Report: The Inventory Report records comprehensive inventory data of your network, including device data, module data, interface data, site data and more.
- Export a Map to a Different File Format: Generate real-time or historical reports to analyze network health, utilization, or incident patterns. Customize and schedule reports to meet your compliance and operational needs.
Change Analysis: Change Analysis (CA) summarizes the data changes within a time period for devices in NetBrain.
- Use Dashboard to Visualize Multi-dimensional Data: Leverage customizable network dashboards to visualize data from multiple sources.
