Export Map in Multiple File Formats
You can export a map to various formats to share information, include maps in reports, or use them in other applications. NetBrain supports exporting to Microsoft Word, Visio, Xmap, and standard image formats.
This section includes the following export options:
Export a Map to a Word Document – Create a Word document that includes the map and associated data.
Configure Export Settings for a Map – Customize what content and layout appear in the exported Word document.
Export a Map to Visio, Xmap, or an Image – Export the map in Visio, Xmap, PNG, or JPEG formats for broader compatibility and sharing.
Use these features to export maps in the format that best suits your workflow or documentation needs.
