Dynamic Map Overview
Dynamic Map technology delivers a single pane of glass (SPOG) management console designed to provide complete visibility across your hybrid IT infrastructure. It serves as an intuitive, interactive user interface that allows you to visualize, navigate, and analyze your network topology in real time.
At the core of Dynamic Map is the Network Discovery Engine, a robust system that continuously maps and monitors your environment to create a Digital Twin, a live, virtual representation of your network. This Digital Twin enables users to gain deep insights into the operational status of the network, helping to quickly detect and troubleshoot issues as they arise.
Dynamic Map integrates real-time data from multiple management sources into a consolidated, unified view, which not only streamlines operations but also enhances situational awareness and decision-making. Whether you are investigating a performance issue, validating network changes, or simply monitoring ongoing operations, the Dynamic Map provides the context and clarity needed to manage complex hybrid infrastructures efficiently.
Dynamic Map empowers you with:
  • Real-time visualization of the entire network topology
  • Integrated diagnostics and alerting from multiple monitoring systems
  • Drill-down capabilities to isolate and resolve problems quickly
  • Seamless navigation through interconnected devices and services
