R12.1-2025July30
Defining Network Intent Cluster
Follow the steps to define Network Intent Cluster:
  1. Define Input Devices.
  2. Define Seed NI.
  3. Define Seed Logics.
  4. Define Device Classifiers.
  5. Define Eigen Variables.
  6. Define Target Seed
  7. Create Member NIs.
Define NIC in Auto Mode
By enabling Auto Mode, you need to define only Input Devices and seed NI. And all other nodes are automatically generated, The only requirement is the Seed NI should not have cross-device diagnosis and macro variables.
