Define Import File Wizard
Import File Wizard has four guiding tabs:
- Step 1: Upload File: Import text files of device commands and define how to parse these files.
- Step 2: Identify Device & Data: Display the parsed data, and adjust the detection logic and redetect the imported files if the parsed data is incorrect. The device driver conflicts can also be resolved here.
- Step 3: Commit: Build the device model and import the command data to the system by committing the detected data.
- Step 4: Build Dataset in ADT: Build the dataset for an existing ADT or a new ADT by adding the imported data to the ADT.
