Logo
Configure Installed NIT
For a newly installed NIT, you can further define the configurations of the NIT in the right pane.
You can follow the procedures listed below to configure NIT, then click Apply at the bottom-right of the right pane to apply the settings.
  1. Configure Intent Decoding
  2. Configure Intent Timer
  3. View Cloned Intents in IBA Center
  • NIT Baseline Decoding
Install Intent Configure Intent Decoding
