Build Column Group with Network Objects
Network Objects properties can be used to populate column group data. The corresponding four methods using network object properties are listed below:
- Build Column Group with Map Properties
- Build Column Group from Filtered Path Intents
- Build Column Group from Intent Cluster
- Build Column Group from Probes
