Build Column Group from Probes
Associate Probes for Automation Asset Preventive Automation
Probes installed for ADT can trigger the automation process associated with the ADT automation assets. The corresponding PDAS flow is shown in the diagram below.
A picture containing timelineDescription automatically generated
A probe column can be defined for using the primary and secondary probes to trigger automation with assets in the ADT. The probe properties are used as the built-in data for the probe column. The Flash alerts generated by the probes can also be the available data source.
The follow diagram illustrates how Monitoring Probe functions in Column Group Builder:
Graphical user interface  Description automatically generated
For the specific steps of building the column group with probes, see Preventive Automation via ADT.
