R12.1-JA-2025June05 Automation Basis Visual Parser Advanced Parser Network Intent Network Intent Template Intent Replication Wizard Intent-based Automation Center Network Intent Cluster Automation Data Table (ADT) ADT Dataset Import File Wizard Dashboard CLI Command Template Qapp Gapps Runbook Runbook Template Part III: Problem Diagnosis and Preventive Automation Visual Parser
