Map Tools and Keyboard Shortcut
Learn map tools and keyboard shortcuts to become a pro at NetBrain maps.
Map Tool
Click Map on the Map Toolbar to open the toolbox.
| Tool Icon | Function | Keyboard Shortcut |
![]() | See Auto Layout for more details. | |
![]() | See Update a Map for more details. | |
| See Refresh a Map for more details. | ||
![]() | Editing Rights: Automatically release Editing Rights when close map: Enable automatically release Editing Rights when close the map Transfer Editing Rights: Transfer editing rights to other user. | |
| Lock a map with/Without password. See Lock a Map for more details. | ||
Map Device Layout: Provide two modes to control whether the map can be directly edited.
![]() | See Map Page Settings for more details. | |
![]() | Path Legend: View paths associated with the current Map. | |
![]() | Undo | Ctrl + Z |
![]() | Redo | Ctrl + Y |
| Select Mode Free-hand Select: The default mode. You can click the desired map objects and adjust them at will. Area Select: Select map objects by dragging your mouse to select an area. | N/A
![]() | Search: direct to the search bar | |
![]() | Save: Save the current map. | Ctrl + S |
![]() | Save As: Save a copy of the current Map with a different map name. | |
![]() | Print | Ctrl + P |
![]() | Copy Map URL: Copy the URL of the current Map. | |
![]() | See Export a Map for more details. |
Keyboard Shortcut
| Category | Action | Shortcut | ||
| Select map objects | Select multiple map objects | Hold the Ctrl key while selecting map objects. | ||
| Bulk select map objects by object type, such as sites or devices belonging to the same device type. | Hold the Shift key while selecting a map object belonging to the target type. | |||
| Select map objects by area | Hold the left mouse button for 2 seconds at least, and then select an area. | |||
| Select all objects on a Map | Ctrl + A | |||
| Alignment | Align the selected map objects to the left | Alt + L | ||
| Align the selected map objects to the center | Alt + C | |||
| Align the selected map objects to the right | Alt + R | |||
| Align the selected map objects to the top | Alt + T | |||
| Align the selected map objects to middle | Alt + M | |||
| Align the selected map objects to the bottom | Alt + B | |||
| Zoom Controls | Zoom in | Rotate the mouse wheel button forward. | ||
| Zoom out | Rotate the mouse wheel button backward. | |||
| Move map objects | Move the whole Map | Drag your mouse while holding the left mouse button, or press the Arrow key (↑↓←→). | ||
| Move specific objects | Selecting the objects, and then press the Arrow key (↑↓←→) or drag the objects with the mouse.
| Others | Undo | Ctrl + Z | ||
| Redo | Ctrl + Y | |||
| Print a map | Ctrl + P | |||
| Save a map | Ctrl + S |
