Lock a Map
To avoid mis-operations on the map, the map can be locked by completing the following steps.
- On the Map Toolbar, navigate to Map > Lock Settings.
- Define lock settings in the pop-up dialog. Turn on Lock to enable lock setting, then define to lock a map with password or without password. For more information, see Lock Function.
- Click OK to finish lock settings. Then your Map will become view-only to users without corresponding privilege and limited operations can be performed, such as:
- Compare network changes
- Share
- Save
- Zoom controls
Tip: To unlock the Map, click Unlock.
