Data Unit is the fundamental and smallest unit in a data view, and displayed on device or interface labels.
Data units come from the following data sources:
▪Built-in data, including GDR properties and built-in device data table (general data table and NCT table)
▪Parser variables (saved in the Parser Library)
Tip: You can customize the display setting for parser and API variables. See Configuring Variable Display Settings for more details.
The specific data units supported on both device and interface positions are as follows:
Position |
Supported Data Units |
▪Built-in data ▪Single value parser variables (legacy device only) |
Device Position |
▪Single value or table type parser variables ▪Built-in device data tables ▪Single value or table type device-level API variables |
▪Built-in data (legacy interface only) ▪Parser variables in a table with an interface key configured |
Interface Position |
▪Parser variables in a table with an interface key configured ▪Built-in device data tables ▪Interface-level API variables in a table with an interface key configured |
The supported data types of data units in a data view are listed as follows:
