Creating a Discovery Task
A scheduled network discovery can discover new devices from your network and then add them to your domain automatically, and enable you to check the latest status of your network devices on a regular basis. With the scheduled discovery task, you can get to know any newly added devices, decommissioned devices and more.
2.In the Domain Management page, select Operations > Discovery/Benchmark Task from the quick access toolbar.
3.On the Discovery/Benchmark Task tab, click Add Discovery Task.
4.Enter the task name and description.
5.Follow the tabs in the wizard to configure the settings for the task.
Frequency — specify the execution frequency for the task. By default, it is Once.
Network Setting — select the proxies and credentials to be used in the discovery.
Discovery Seed — select a discovery method and then configure the related options.
Discover all live network
Discover the following IPs
Scan the following IPs
Summary — check your configurations.
6.Click Submit. The newly added task is enabled by default.
Tip: After the Discovery task is executed, the system will automatically rebuild IPv4 Layer 3 topology and synchronize with sites.
Scheduling Discovery Tasks
