1.In your web browser, navigate to http(s)://<IP address or hostname of NetBrain Web Server>/. For example, https://10.10.3.141/ or http://10.10.3.141/.
2.In the login page, enter your username or email address, and password.
Note: If your user account is managed in a third-party user management server (LDAP, AD or TACACS+), you need to select the authentication server name from the drop-down list. If your user account is created and managed in NetBrain system, select the NetBrain option.
Note: If you are using SSO (Single Sign-On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
Tip: To go to the administrator login page, click Administrator Login.
3.Click Log In.
Note: If your email address, first name or last name is not stored in the system, you will be required to complete your user profile.
4.Click the domain name from the quick access toolbar and select Manage Domain.
Note: It is not recommended to use the same web browser to log into the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
▪Logging into Tenant Management Page
▪Logging into System Management Page
