1.In your web browser, navigate to http(s)://<Hostname or IP address of NetBrain Web Server>/admin.html. For example, https://10.10.3.141/admin.html or http://10.10.3.141/admin.html.
2.In the login page, enter your username or email address, and password. The initial username/password is admin/admin.
Note: If your user account is managed in a third-party user management server (LDAP, AD or TACACS+), you need to select the authentication server from the drop-down list. If your user account is created and managed in NetBrain system, select the NetBrain option.
Note: If you are using SSO (Single Sign-On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
3.Click Log In.
Note: If your email address, first name or last name is not logged in the system, you may be required to complete your user profile first.
Note: It is not recommended to use the same web browser to log into the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
▪Redirecting to Tenant Management page
