1.In your web browser, navigate to http(s)://<Hostname or IP address of NetBrain Web Server>/. For example, https://10.10.3.141/ or http://10.10.3.141/.
2.In the end user login page, enter your username or email address, and password.
Note: If your user account is managed by a third-party user management server (LDAP, AD or TACACS+), you need to select the authentication server name from the drop-down list. If the account is created and managed in NetBrain system, select the NetBrain option.
Note: If you are using SSO (Single Sign-On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
Tip: To go to the administrator login page, click Administrator Login.
3.Click Log In.
Note: It is not recommended to use the same web browser to log into the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
