1.In your web browser, navigate to http(s)://<IP address of NetBrain Web Server>/admin.html. For example, https://10.10.3.141/admin.html or http://10.10.3.141/admin.html.
2.In the login page, enter your username or email address, and password. The initial username/password is admin/admin.
Note: If your user account is managed in a third-party user management server (LDAP, AD or TACACS+), you need to select the authentication server name from the drop-down list. If your user account is created and managed in NetBrain system, select the NetBrain option.
Note: If you are using SSO (Single Sign On), click the hyperlink of the SSO server to redirect to the login page of your Identity Provider. After your credentials are verified, you will be directly logged in to the system and you can skip step 3.
3.Click Log In.
Note: If you have the privileges of the system administrator, the landing page will be the System Management page. You need to redirect to the Tenant Management page by clicking System in the quick access toolbar and then select the target tenant.
Note: It is not recommended to use the same web browser to log into the system with multiple user accounts. Only the last logged-in user will be recognized as the current user.
▪Redirecting to System Management Page
