This section introduces how to create a network change task as well as the nodes and their functions involved in the network change task.
Tip: Before creating a network change task, ensure that you have sufficient privilege. See Access Controls for more details.
1.Click Network Change on the taskbar.
2.In the Network Change pane, click New Change.
Tip: The Network Change pane displays all network change tasks created in a domain.
3.In the New Network Change dialog, enter the task name, select a template and click OK. The Runbook pane opens. Then you can define the network change task node by node in the runbook.
▪Defining the Benchmark Before node
▪Defining the Benchmark After node
▪Adding and Defining a Change Note Node
4.Click the
icon to save the map. The network change task is saved in the map.
