The Execute node is used to implement one of the defined changes on devices.
Tip: The Execute node cannot be executed unless the change management task is approved. See Defining the Approval Node to submit the approval request.
1.Select the Execute node in the runbook.
2.In the Execute pane, define the following settings:
1)Select a change node from the drop-down list. The related devices and change commands will be loaded.
2)Click the
icon next to the Execute button to set the execution methods:
▪One by One Automatically — push change commands to a device, and then push them to the next device automatically after a brief pause.
▪In Batches Automatically — push change commands to a batch of devices, and then push them to the next batch of devices automatically after a brief pause.
▪One by One Manually — push change commands to a device manually, and you need to click Execute to push commands to the next device manually.
▪Sleep Time between all command — the time interval of sending CLI commands. By default, the interval is 2 seconds.
