The Benchmark Before node is used to store the live data of the involved devices before the task implementation. Additionally, the data will be used as the source for data comparison before and after executing the change management task.
1.Select the Benchmark Before node in the runbook.
2.In the Benchmark Before pane, define the following settings:
1)Click the
icon to select the target devices for the benchmark.
2)Add CLI commands by using either way:
▪Manually enter a CLI command and click Add. You can add multiple commands.
▪Click the
icon to select Load CLI Templates to batch add commands.
3)Click Select Data to select data types that you want to retrieve.
