All devices on a map page are displayed in the default data view. You can apply a single or multiple data views to show different layers of data units on the map.
1.On the map page, click the
icon to open the Data View pane. It lists all the data views applicable to the current map page.
2.In the Data View pane, click a global data view to apply it on the map. Data units in this data view are highlighted with a background color.
Tip: By default, only global data views are listed. To apply local data views, click Global Data View to select Local Data View.
3.Click another data view to apply it on the map page.
To show more layers of data units on a map, you can apply multiple data views. The rule is that the latter applied data view will occupy the positions used by the earlier applied ones. The data units on the occupied positions will be displayed in other positions automatically, including the overflowed positions.
icon to open the Data View pane. It lists all the data views that are applicable to the map page.
2.Click the
icon of your interested data views one by one. The sequence of selections determines the layer display of data views. The latest applied data view will be laid on the top.
Tip: To remove an applied data view, click the
icon. You can also manually reset the layer level of a data view by clicking the layer hyperlink.
Tip: By default, only global data views are listed. To apply local data views, click the
icon to select Local Data View.
Tip: Global data views can be generated by enabling the built-in Qapp/Gapp tasks in the Qapp Scheduler.
3.View different layers of data units on the map page. The
icon indicates that the device has data units on the overflowed positions.
▪Clearing Applied Data Views from a Map
▪Creating a Data View from Templates
