Open Driver, which leverages the low code ability of Visual Parser, enables users to correct the data inaccuracy issues by themselves.
After viewing data inaccuracy issues from Data Accuracy Wizard, follow the steps to define the open driver:
1.Navigate to the Open Driver editor.
2.Define the Data Source, to select or create a Parser to get the exact value you want.
3.Select the target device data, i.e., what data you would like to fix.
4.Map the source data variables to the target device data.
5.Define the qualification for the Open Driver.
