In Open Driver Manager page, you can view and manage all Open Drivers under the domain.
Note: You need to have the Open Driver Management privilege to manage Open Drivers.
1.Click
and select Open Driver Manager.
2.In the Open Driver Manager page, you can:
oAdd a new Open Driver
oEdit an Open Driver
oDelete an Open Driver
Open Driver Manager has three types of Open Driver.
Type |
Built-in Open Driver |
Created by the NetBrain team and will be updated via Knowledge Cloud (KC). |
Beta Open Driver |
•Created by the NetBrain team and will be updated via KC. •are not enabled to run by default. The user can test run a beta Open Driver and enable this Open Driver if the results are satisfying. •After has been tested successfully with customers, the NetBrain team will move a beta Open Driver to be a built-in one. |
Customer-defined Open Driver |
You can create a new folder under this root node and create/edit/delete an Open Driver. |
