Path Browser is used to view and manage your saved paths.
You can manage paths based on applications in the Path Browser:
Tip: To use the full functions of the path browser, you need to purchase an AAM license, otherwise, you cannot new application and only can save the path in “Untitled Application”.
▪Organize Paths Based on Applications
▪Organizing and Verifying Paths in Application Manager
