1.Click Path on the taskbar to open the Path Browser.
2.To select the path for recalculation, right-click the target path entry and select the corresponding menu from the drop-down menu.
Tip: To recalculate multiple paths at one time, select the paths by pressing the Ctrl or Shift key.
▪Calculate Live Path — calculate the path with live data.
▪Calculate Path with Advanced Options — An Advanced Option pop-up window will show up, and you can select Path type and Data Source accordingly. See more details in Path Settings.
▪Add to Path Calculation Bar: The Source and Destination IP will be populated to Path Calculation Bar.
