Mapping a Historical Path
To map a path with the latest calculation result, do the following:
1.Click Path Browser on the taskbar.
2.Right-click a path and select Draw Latest Path on Map.
Tip: To map a path with historical calculation results, click the hyperlink of numbers in the History column, and right-click an entry according to the start time of calculation and then click Open Path in Map.
Tip: To re-calculate the path instantly, you can right-click the path and select Calculate Live Path or Add to Path Calculation Bar to calculate the path .
