Each tenant has its global data repository (GDR), in which you can add, edit, and delete device properties, interface properties, and module properties. All domains under a tenant share the same copy of device properties.
The following table lists all possible attributes for a device property (or interface/module property) in GDR.
Attribute |
Property Name |
A unique name of the property (case-sensitive). |
Display Name |
The name displayed in the Device Details pane. |
Map Indicator |
The label added in front of the property value to make it more readable when its value is displayed on the map. This field can be empty. |
Data Type |
The data type of the property. The supported data types are string, double, int, bool, list, and table. See Supported Data Types for more details. Tip: After you add a table type property, you can add sub-properties to it. The device types that the sub-properties apply to inherit from the table type property. The Table Key attribute controls whether to use the sub-property as the key when comparing the table type property. |
Sub Data Type |
The data type of each value in a list type property. The supported sub data types are string, double, int, and bool. |
Control whether to use the property as an index in global search. It is enabled by default. |
Control whether to use the property as search criteria in Advanced Search and Dynamic Search. It is enabled by default. |
Manual Editing |
Control whether you can manually edit the property value in the Device Details pane. It is enabled by default. |
Filter Criteria |
Control whether to use the property as a search criterion to filter devices when running a parser or a Qapp. It is disabled by default. See Advanced Filter and Filter Criteria for more details. |
Visible in Device Details Pane |
Control whether to display the property in the Device Details pane and Inventory Report. It is enabled by default. |
Visible in Data View |
Control whether you can add the property to a position when creating a data view template. It is enabled by default. |
Apply to |
The device types that the property can be applied to. |
Type |
The predefined property category, including: ▪System — the properties predefined in the system, which cannot be modified. ▪Built-in — the properties predefined in the system, but still can be modified by tenant administrators. ▪Customized — the properties added by tenant administrators. |
By default, the following built-in interface types can be visualized on a map:
You can also customize a new interface type. See Adding an Interface Type for more details.
The supported data types for a property are as follows:
▪string
▪double
▪int
▪bool
▪list
▪table
