2023-Nov-03-R11.1a
Supporting Variables
Supporting variables contain a group of key metrics referenced or defined in a data view template definition, including:
- Built-in variable (GDR property)
- CLI/SNMP/API/Configuration Parser variable
- Compound variable
- Input variable
Supporting variables can be used as or applied to:
- Device/interface positions.
- Device/interface notes.
- Device/interface highlights.
- Referenced as a variable to define the conditions for recommended automations.
- Conditions to control the display of variables, device/interface notes, device/interface highlights, and device-level recommended automations.
Note: Supporting variables belong to the data view template level, and can be used in all branches of a data view template.
