2023-Nov-03-R11.1a
Define Replication Logic in NI Editor
The system shows key replication logics under the Replication Logic tab in the intent editor. This tab displays all configurations related to intent replication and contains the entrances for Device Qualification, Macro Variable for Seed Command, Critical Variable, and more additional settings in Full Settings for Template dialog, enabling you to easily find the settings related to intent replication and know which are the key steps to configure an intent as template.
You can also install the replication by wizard.
