2023-Nov-03-R11.1a
Compare Network Data Changes
The Comparison feature is mainly used to compare network data at two time periods to check whether a network has any changes. It can automatically visualize and highlight detailed differences between two sets of network data. With this feature, you can quickly find out the network changes to address the root cause of a network problem.
Network data that can be compared include:
  • Configuration file and parser variables
  • CLI command output and parser variables
  • Data tables (route table, ARP table, NDP table, NCT table, MAC table, and so on)
Comparison Method
The system provides the following two comparison methods:
